davide-prandelli
1 year agoNativeLink error when try to run QuestaSim simulation
Hi, I'm having problems with NativeLink. Quartus (std) doesn't open QuestaSim. I specified the correct location in EDA tools options and I set the simulation and NativeLink settings (tool name and t...
RichardT_altera
1 year agoAny update on this? Do you observe similar issue with supported OS?
I would suggest uninstall Quartus & Questa (everything related to Altera software) and reinstall again.
Do take note that you may try to install Altera software on the non-supported OS but you will have to bear your own risk and there will be no technical support as well.
Richard Tan
