davide-prandelli
1 year agoNativeLink error when try to run QuestaSim simulation
Hi, I'm having problems with NativeLink. Quartus (std) doesn't open QuestaSim. I specified the correct location in EDA tools options and I set the simulation and NativeLink settings (tool name and t...
RichardT_altera
1 year agoCould you try running the example design from the user guide below to determine if the issue is design-dependent?
https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/simulation-quick-start.html
Additionally, the OS you are using does not appear to be officially supported. Please try running the simulation on a different machine with a supported OS to check if the issue persists.
Richard Tan
