11 years ago
Multiplication VHDL
Hi, i have problems with my vhdl code.
can you help me plz
This is the code:
library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all ;
entity correla is
port (
         clk : in    std_logic ;
         rst : in    std_logic  ;
         data: in    std_logic_vector(11 downto 0)  ;
         code: in    std_logic_vector(15 downto 0 )  ;
         Q   : out   std_logic_vector(17 downto 0) )  ;
end entity ;
architecture arch of correla  is
       type RAM is array (0 to 3) of integer range -8 to 7 ;
        signal CD   : RAM;
        signal temp :integer range 0 to 15;
        signal i    :integer range 0 to 3 ;
       signal sum   :integer range 0 to 16  ;
       signal AB    :integer range 0 to 17 ;
begin
                 CD(0)<=to_integer(code(15 downto 12));
                 CD(1)<=to_integer(code(11 downto 8)) ;
                 CD(2)<=to_integer(code(7 downto 4 )) ;
                 CD(3)<=to_integer(code(3 downto 0))  ;
     étalement:process(clk,rst)
        begin
                  if(rst='1') then
                     Q<=(others=>'0');
                       i<= 0  ;
                      temp<=0;
                      AB<=0;
                   else
                        if(clk'event and clk ='1') then
                            sum<=0;
                                temp<=to_integer(data(i)*code(i)) ;
                                      i<=i+1 ;
                                  sum<=sum(i) +(temp(i)+temp(i+1)) ;
                             end if ;
                     end if ;
                        AB<=sum ;
                         Q<=std_logic_vector(AB) ;
            end process ;
 end architecture ;
