I am not sure but you should remove the line "use IEEE.std_logic_arith.all;", It may redefine operators.
Avoid éèçàù... : c'est trop français pour du VHDL ;-)
Be aware that integer = 32 bits in VHDL
VHDL needs a very strict description :
Your 'i' is integer range 0 to 3. OK
somewhere you have
i<=i+1 ;
What happens if i = 3 ? Not sure that i returns to 0 !
if i <= 3 then
i <= i + 1;
else
i <= 0;
end if;
What is the value of "sum" when rst = '1' ?
You must initialize ALL signals to avoid spending hours to debug.
BUT your VHDL does NOT describe your schéma !!!
For a beginner, If your design have always 4 mult and 3 add,
I advise you to draw your schema completely : all signals are named.
Write your VHDL element per element :
mult1 : ... <= ... * ... ;
mult2 : ... <= ... * ...;
add1 : ... <= ... + ....; -- be careful that with IEEE.numeric_std : 16bits + 16bits => 16bits, not 17bits !!
And add a D flip flop at the end, to stay synchronous.
To create a D flip flop, it is just a
process(rst,clk)
begin
if rst = '1' then
Q <= (others => '0');
elsif rising_edge(clk) then
Q <= AB; -- AB is the result of the "logique combinatoire" which may glitchs
end if;
end process;
later, you can make this design more generic as you badly tried. use generic, generate... In a near future, if fmax is not satisfied, you can pipeline : insert D flip flop between mult and add, but it increase latency.
Welcome to the dark side of VHDL ;-)
golden rule[/orange] :
vhdl is a description language, NOT a program.
