17 years ago
multiple constant drivers for net IOP_
hi. I have the errors as mentioned in the title by running it in version 7.1. However, i have no error in running it in version 8.1 and have 108 warnings. May i know how to solve this error? Thanks.
This is the code as below:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity IOP_ALU is
generic (
m: integer := 28;
n: integer := 8
port (
-- Enter port list here
clk_25mhz : in std_logic;
reset_b : in std_logic;
serial_in : in std_logic;
serial_out : out std_logic
end IOP_ALU;
architecture IOP_ALU_arch of IOP_ALU is
signal ack, busy : std_logic;
signal inputpin : std_logic_vector(m-1 downto 0);
signal outputpin : std_logic_vector(n-1 downto 0);
signal selop : std_logic_vector(3 downto 0);
signal R0 : std_logic_vector (7 downto 0);
signal A : std_logic_vector(7 downto 0);
signal B : std_logic_vector(7 downto 0);
signal alu_out : std_logic_vector(7 downto 0);
signal ccr : std_logic_vector(1 downto 0);
component ALU_2
port (
ccr : buffer STD_LOGIC_VECTOR(1 downto 0);-- ccr(1)-negative, ccr(0)-zero
R0 : in std_logic_vector(7 downto 0);
A : in STD_LOGIC_VECTOR(7 downto 0);
B : in STD_LOGIC_VECTOR(7 downto 0);
selop : in STD_LOGIC_VECTOR(3 downto 0);
-- ccr_out : out STD_LOGIC_VECTOR(2 downto 0);
alu_out : out STD_LOGIC_VECTOR(7 downto 0)
end component;
component IOP
generic (
n: integer := n;
m: integer := m
port (
-- testing_cout_out : out std_logic_vector(7 downto 0);
reset_b : in STD_LOGIC;
serial_out : out std_logic;
-- error1 : out std_logic;
-- error2 : out std_logic;
clk_25mhz : in STD_LOGIC;
-- input_eq : out std_logic;
-- t_out_equal : out std_logic;
inputpin : buffer std_logic_vector(m-1 downto 0);
outputpin : in std_logic_vector(n-1 downto 0);
ack : out std_logic ;-- signal from to indicate continue CPU execution
busy : in std_logic -- signal to indicate transfer data
end component;
begin
inputpin <= selop & R0 & A & B;
outputpin <= alu_out;
-- VHDL Module Generator component instantiations
U_ALU_2: ALU_2
port map (ccr, R0, A, B, selop, alu_out);
U_IOP: IOP
port map (reset_b, serial_out, serial_in, clk_25mhz, inputpin, outputpin, ack, busy);
-- Enter concurrent statements here
end IOP_ALU_arch;
    Your "inputpin" is driven twice once in the comb. statement and once in the instantiation of IOP. Buffer means output, you better avoid this type of port. Your signal names are very confusing.
    IOP_ALU consists of 2 module: IOP and ALU(DUT). the inputpin mentioned(confused) is the input to DUT which is the output of the IOP as you can view in the attachment. Actually i study on somebody code and i cant answer you about the use of buffer.
    At the same time i would like to ask that is the mode buffer in verilog as well? If yes what is the function.
    As you comment before, there are combination statement and instantiation statement. On the other hand, it is working when i compile the module IOP. It also contain the combination statement and instantiation statement. The code of IOP is as bellow:
    -- final_lo
    library IEEE;
    entity IOP is
    generic (
    n: integer := 28;
    m: integer := 8
    port (
    end IOP;
    architecture IOP_arch of IOP is
    signal clk_1mhz_int : std_logic;
    signal sig_idle,ready_in :std_logic;
    signal t_out_eq,eq_zero : std_logic;
    signal data_selected : std_logic_vector(7 downto 0);
    signal data_fsm : std_logic_vector(7 downto 0);
    signal control : std_logic_vector(16 downto 0);
    signal get_data,fsm_data_load,t_input_load,t_output_load,i_load,i_inc,i_clr,o_load,o_inc,o_clr,transfer : std_logic;
    signal data_selected_load : std_logic;
    signal trans,recv : std_logic;
    signal load_command : std_logic;
    signal data_selected_reg : std_logic_vector(7 downto 0);
    signal end_data : std_logic_vector(1 downto 0);
    signal data_out : std_logic_vector(8 downto 0);
    signal command : std_logic_vector(7 downto 0);
    -- VHDL Module Generator component declarations
    component clk_1mhz
    port (
    reset : in STD_LOGIC;
    clk_1mhz : out STD_LOGIC
    end component;
    component IOP_CU
    port (
    clk_1mhz : in STD_LOGIC;
    sig_idle : in STD_LOGIC;
    ready_in : in STD_LOGIC;
    t_out_eq : in STD_LOGIC;
    eq_zero : in STD_LOGIC;
    data_selected : in STD_LOGIC_VECTOR(7 downto 0);
    data_fsm : in std_logic_vector(7 downto 0);
    control : out STD_LOGIC_VECTOR(16 downto 0);
    command : in std_logic_vector(7 downto 0);
    ack : out std_logic ;-- signal from io processor to indicate continue execution
    busy : in std_logic -- signal to io processor to indicate interrupt to transfer data
    end component;
    component IOP_DPU
    generic (
    n: integer := 12;
    m: integer := 12
    port (
    transfer : in std_logic;
    get_data : in std_logic;
    clk25mhz : in STD_LOGIC;
    clk_1mhz : in std_logic;
    sig_idle : out std_logic;
    ready_in : out std_logic;
    i_load : in std_logic;
    i_inc : in std_logic;
    i_clr : in std_logic;
    o_load : in STD_LOGIC;
    end_data : in std_logic_vector(1 downto 0);
    o_inc : in STD_LOGIC;
    o_clr : in STD_LOGIC;
    t_out_eq : out STD_LOGIC;
    eq_zero : out std_logic;
    data_selected_reg : buffer std_logic_vector(7 downto 0);
    data_fsm : out std_logic_vector(7 downto 0);
    t_input_load : in STD_LOGIC;
    t_output_load : in std_logic;
    fsm_data_load : in std_logic;
    data_selected_load : in std_logic;
    trans : in std_logic;
    recv : in std_logic;
    load_command : in std_logic;
    command : buffer std_logic_vector(7 downto 0)
    end component;
    begin
    load_command<=control(16);
    get_data<=control(15);
    fsm_data_load<=control(14);
    data_selected_load<=control(13);
    t_input_load<=control(12);
    t_output_load<=control(11);
    i_load<=control(10);
    i_inc<=control(9);
    i_clr<=control(8);
    recv<=control(7);
    trans<=control(6);
    o_load<=control(5);
    o_inc<=control(4);
    o_clr<=control(3);
    end_data(1)<=control(2);
    end_data(0)<=control(1);
    transfer<=control(0);
    u_clk_1mhz: clk_1mhz
    port map (reset_b, clk_25mhz, clk_1mhz_int);
    u_iop_cu: iop_cu
    port map (reset_b, clk_1mhz_int, sig_idle, ready_in, t_out_eq, eq_zero, data_selected, data_fsm, control,command,ack,busy);
    u_iop_dpu: iop_dpu
    generic map (n,m)
    port map (transfer, get_data, reset_b, clk_25mhz, clk_1mhz_int, serial_out, sig_idle, serial_in, ready_in, i_load, i_inc, i_clr, o_load,end_data(1 downto 0),o_inc,o_clr,t_out_eq, eq_zero, data_selected, data_fsm, t_input_load, t_output_load, fsm_data_load,data_selected_load,trans,recv,inputpin,outputpin,load_command,command);
    end IOP_arch;
    Howerver there are errors in top level IOP_ALU. Can you explain on it. Thanks
    There are two issues that I raised. One is your error of double drive, the second is a recommendation about buffer port.
    Your error will appear when you connect IOP & ALU as one project. You are driving inputpin from two sources:
    Drive 1: inputpin <= selop & R0 & A & B;
    Drive 2: inputpin is driven by IOP module
    I am not saying don't mix comb. with other statements but you can't drive from more than one source in VHDL. If you need more than one drive then you must write a correct construct to resolve the drive.
    As to buffer port: This is almost obsolete type of vhdl port(not verilog). It is meant for outputs that need to be read inside module instead of intermediary signal. You better avoid it and use intermediary signal if you want to read your output. Verilog has "buf" which is not a port but actual buffer function.
    I aggree, that buffer can and should be avoided. The problem however isn't due to the buffer port type rather than the fact, that's an output (as any buffer).
    To add my strongest personal dislikings in the present post: Positional association with component instantiation. And - unneccessary long example code, that could be easily reduced, which would be also the first step to locate the coding error by yourself.
    Thanks for the advice.
    Why there is error in version 7.1 and no error in version 8.0? Just wonder..
    How to
    What is the meaning of “ ”?
    for example :
    generic (
    Note: note := "Receiver shift register"
    Regarding the second question, it's a VHDL string constant. Cause VHDL strings aren't directly synthesizable (at best, they may be casted to a synthesizable type in some cases), they are mainly used as generics with parameterizable components and in simulation.
    --- Quote Start ---
    --- Quote End ---
    Cause I wasn't able to validate the error from the presented code, I can just guess. It may be the case, that the said buffer port isn't driven in the component (so, it isn't actually an output) and that the Quartus behaviour was changed in this respect. I remember some oddities with inconsistent defined buffer ports with previous Quartus versions. The issue can be verified only by interrogating the component code.
