17 years agoIOP_ALU consists of 2 module: IOP and ALU(DUT). the inputpin mentioned(confused) is the input to DUT which is the output of the IOP as you can view in the attachment. Actually i study on somebody code and i cant answer you about the use of buffer.
At the same time i would like to ask that is the mode buffer in verilog as well? If yes what is the function. As you comment before, there are combination statement and instantiation statement. On the other hand, it is working when i compile the module IOP. It also contain the combination statement and instantiation statement. The code of IOP is as bellow: -- final_lo library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; entity IOP is generic ( n: integer := 28; m: integer := 8 ); port ( -- testing_cout_out : out std_logic_vector(7 downto 0); reset_b : in STD_LOGIC; serial_out : out std_logic; serial_in : in std_logic; -- error1 : out std_logic; -- error2 : out std_logic; clk_25mhz : in STD_LOGIC; -- input_eq : out std_logic; -- t_out_equal : out std_logic; inputpin : buffer std_logic_vector(m-1 downto 0); outputpin : in std_logic_vector(n-1 downto 0); ack : out std_logic ;-- signal from to indicate continue CPU execution busy : in std_logic -- signal to indicate transfer data ); end IOP; architecture IOP_arch of IOP is signal clk_1mhz_int : std_logic; signal sig_idle,ready_in :std_logic; signal t_out_eq,eq_zero : std_logic; signal data_selected : std_logic_vector(7 downto 0); signal data_fsm : std_logic_vector(7 downto 0); signal control : std_logic_vector(16 downto 0); signal get_data,fsm_data_load,t_input_load,t_output_load,i_load,i_inc,i_clr,o_load,o_inc,o_clr,transfer : std_logic; signal data_selected_load : std_logic; signal trans,recv : std_logic; signal load_command : std_logic; signal data_selected_reg : std_logic_vector(7 downto 0); signal end_data : std_logic_vector(1 downto 0); signal data_out : std_logic_vector(8 downto 0); signal command : std_logic_vector(7 downto 0); -- VHDL Module Generator component declarations component clk_1mhz port ( reset : in STD_LOGIC; clk_25mhz : in STD_LOGIC; clk_1mhz : out STD_LOGIC ); end component; component IOP_CU port ( reset : in STD_LOGIC; clk_1mhz : in STD_LOGIC; sig_idle : in STD_LOGIC; ready_in : in STD_LOGIC; t_out_eq : in STD_LOGIC; eq_zero : in STD_LOGIC; data_selected : in STD_LOGIC_VECTOR(7 downto 0); data_fsm : in std_logic_vector(7 downto 0); control : out STD_LOGIC_VECTOR(16 downto 0); command : in std_logic_vector(7 downto 0); ack : out std_logic ;-- signal from io processor to indicate continue execution busy : in std_logic -- signal to io processor to indicate interrupt to transfer data ); end component; component IOP_DPU generic ( n: integer := 12; m: integer := 12 ); port ( -- testing_cout_out : out std_logic_vector(7 downto 0); transfer : in std_logic; get_data : in std_logic; reset_b : in std_logic; clk25mhz : in STD_LOGIC; clk_1mhz : in std_logic; serial_out : out std_logic; sig_idle : out std_logic; serial_in : in std_logic; -- error1 : out std_logic; -- error2 : out std_logic; ready_in : out std_logic; i_load : in std_logic; i_inc : in std_logic; i_clr : in std_logic; -- input_eq : out std_logic; o_load : in STD_LOGIC; end_data : in std_logic_vector(1 downto 0); o_inc : in STD_LOGIC; o_clr : in STD_LOGIC; t_out_eq : out STD_LOGIC; eq_zero : out std_logic; data_selected_reg : buffer std_logic_vector(7 downto 0); data_fsm : out std_logic_vector(7 downto 0); t_input_load : in STD_LOGIC; t_output_load : in std_logic; fsm_data_load : in std_logic; data_selected_load : in std_logic; trans : in std_logic; recv : in std_logic; inputpin : buffer std_logic_vector(m-1 downto 0); outputpin : in std_logic_vector(n-1 downto 0); load_command : in std_logic; command : buffer std_logic_vector(7 downto 0) ); end component; begin -- VHDL Module Generator component instantiations load_command<=control(16);get_data<=control(15);
fsm_data_load<=control(14);
data_selected_load<=control(13);
t_input_load<=control(12);
t_output_load<=control(11);
i_load<=control(10);
i_inc<=control(9);
i_clr<=control(8);
recv<=control(7);
trans<=control(6);
o_load<=control(5);
o_inc<=control(4);
o_clr<=control(3);
end_data(1)<=control(2);
end_data(0)<=control(1);
transfer<=control(0);
u_clk_1mhz: clk_1mhz
port map (reset_b, clk_25mhz, clk_1mhz_int);
u_iop_cu: iop_cu
port map (reset_b, clk_1mhz_int, sig_idle, ready_in, t_out_eq, eq_zero, data_selected, data_fsm, control,command,ack,busy);
u_iop_dpu: iop_dpu
generic map (n,m)
port map (transfer, get_data, reset_b, clk_25mhz, clk_1mhz_int, serial_out, sig_idle, serial_in, ready_in, i_load, i_inc, i_clr, o_load,end_data(1 downto 0),o_inc,o_clr,t_out_eq, eq_zero, data_selected, data_fsm, t_input_load, t_output_load, fsm_data_load,data_selected_load,trans,recv,inputpin,outputpin,load_command,command); end IOP_arch; Howerver there are errors in top level IOP_ALU. Can you explain on it. Thanks
