10 years agoMultiple constant driver error
[h=1]This is the verilog code i have written in quartus 2 .... Bt after compilation i m getting "Can't resolve multiple constant drivers for net" such errors.... i guess it is something related to the always block... how should i correct those errors... i m new to quartus2 ... plz let me know if there is any solution to this..
module switch_model( s0,s1,s2,s3,rst,clk); input rst,clk; output reg s0,s1,s2,s3; reg [15:0] counter; // reg clk_50; initial begin s0=1'b0; s1=1'b0; s2=1'b0; s3=1'b0; end genvar i; generate for (i=0;i<255;i=i+1) begin always @(posedge clk) begin s0<=1'b1; s1<=1'b1; # 50 s2<=1'b1; s3<=1'b1; end end endgenerate endmodule[/h]2 Replies
you have created 256 always blocks, all driving s0, s1, s2 and s3 to 1'b1, hence the multiple constant drivers.
Get rid of the generate. Btw, your circuit does nothing except drive all outputs to '1b1 forever. - Altera_Forum
thankss... after removing for loop, atleast i got id of those errors....
yes i need to complete the code...
