L982123
6 years agoMulti-phase data recovery design constraints
I have a design where an input is being oversampled by using multiple phase outputs from a PLL. To make this work I need to ensure that the skew between the input and each sampling register is...
KhaiChein_Y_Intel
6 years agoHi,
Does the skew value in the report_skew report less than the value you set using set_max_skew? Can you check if this constraint is being ignored and listed in the Ignored Constraints report? Have you tried setting the clock to global signal?
KhaiY
