9 years agoModule Declaration Question for Transceiver Design
Hi, I was hoping someone could answer a fairly simple question. Here is my module declaration code for a transceiver design:
module xcvr_prbs ( //inputs input wire phy_mgmt_clk, input wire pll_ref_clk, input wire reset_reset, input wire reconfig_reset, input wire rx_serial_data, input wire rx_seriallpbken, input wire xgmii_tx_clk, input wire rx_serial_data_0, input wire xgmii_tx_dc_0[71:0], output wire xgmii_rx_clk, output wire rx_data_ready, output wire xgmii_rx_dc_0[71:0], output wire tx_serial_data_0, //ouputs output wire errorFlag, output wire [100:0] errorCount, output wire tx_serial_data, output wire tx_ready, output wire rx_ready, output wire [63:0] prbs_data_rx_top ); My question is, how do I know whether to put input/output wires and registers inside the module parenthesis, or outside the parenthesis? I have been following some example transceiver designs and in those examples, some wires are declared inside and some outside. I am assuming the ones declared inside the module also need pin assignments. Is that correct? Thanks in advance!2 Replies
There are two styles of module header declarations; one from Verilog-1995 where you might have to mention a port name up to three times, and the one you are using from Verilog-2001 and later where everything is in one place.
See http://stackoverflow.com/questions/12229477/why-are-output-nets-also-required-to-be-redeclared-as-either-wire-or-reg - Altera_Forum
Thanks for the response. However, in my design, there are single declarations of different variables, not multiple declarations of the same variable; some are declared inside the parenthesis, some are outside. At least, this is what the native phy example I am following does and I am not sure how to decide what variables to declare inside and outside the module declaration.
