10 years agoModular SGDMA Streaming
Hi, I'm trying to stream data from an ADC to my DDR RAM. I’ve hit a roadblock with using the modular SGDMA core to do streaming to memory mapped transfers to DDR RAM. An interrupt that is suppo...
10 years agoHi Daixiwen,
I've attached a screenshot of the signals being tapped from the write master's data sink, it looks like the streaming data is going through correctly. The CSR IRQ also goes off which indicates when the write is complete. However, there is a problem on the software side, the exception does not get handled. The way I have the system set up right now is I "fake" an avalon streaming interface to stream data from an ADC to a FIFO. That fifo is connected to the data sink of the SGDMA using the avalon streaming interface. I used a PIO to allow the NIOS II software to set the valid bit of the top level module's "fake" streaming avalon bus (this signal is tapped and shown in the attached image as "adc_ready_pio_export"). The interrupt signal is also shown as "csr_irq". The interrupt remains at 1 after the standard descriptor register is written to. It seems like the nios 2 processor registers an unhandled exception right after interrupt signal goes up. The following are the instructions that get called prior to the interrupt going off (the PIO that controls the write is set to high) and the assembly instructions of the exception handler. 90 IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE, 1); 00000320: movi r3,1 00000324: movhi r2,16388 00000328: addi r2,r2,2128 0000032c: stwio r3,0(r2) 96 if(value == 0){ 00000330: ldw r2,-4(fp) alt_exception_unknown: 40000094: break 0 40000098: ldw r5,68(sp) 4000009c: ldw ea,72(sp) 400000a0: ldw ra,0(sp) 400000a4: wrctl estatus,r5 400000a8: ldw at,8(sp) 400000ac: ldw r2,12(sp) 400000b0: ldw r3,16(sp) 400000b4: ldw r4,20(sp) 400000b8: ldw r5,24(sp) 400000bc: ldw r6,28(sp) 400000c0: ldw r7,32(sp) 400000c4: ldw r8,36(sp) 400000c8: ldw r9,40(sp) 400000cc: ldw r10,44(sp) 400000d0: ldw r11,48(sp) 400000d4: ldw r12,52(sp) 400000d8: ldw r13,56(sp) 400000dc: ldw r14,60(sp) 400000e0: ldw r15,64(sp) 400000e4: addi sp,sp,76 400000e8: eret I also printed out the register values at the time the exception occurs: zero 0 at 3735928559 r2 3690725375 r3 488 r4 1 r5 0 r6 2155905152 r7 4278124287 r8 67528 r9 70204 r10 5 r11 3 r12 67532 r13 1073740280 r14 67528 r15 196218880 r16 69016 r17 67552 r18 3735928559 r19 3735928559 r20 3735928559 r21 3735928559 r22 3735928559 r23 3735928559 et 3735928559 bt 4294967295 gp 0x0001a844 sp 0x3ffffeb8 fp 0x3fffff18 ea 0x0bb21004 sstatus 4294967295 ra 0x000001ec pc 0x40000094 status 0 estatus 0 bstatus 4294967295 ienable 5 ipending 1 cpuid 0 ctl6 4294967295 exception 20 pteaddr 4294967295 tlbacc 4294967295 tlbmisc 4294967295 eccinj 4294967295 badaddr 0 config 4294967295 mpubase 4294967295 mpuacc 4294967295 The register that seemed to be the most important was the exception register which held a value of 20. A subset of the exception register corresponds to the cause of the exception. That subset corresponded to cause# 5 which is an "Illegal Instruction Exception". I'm not sure why I'm getting this exception since the instructions being run prior to the interrupt seem valid. Any idea what's causing this problem?
