Bala-Mookkiah's avatar
Bala-Mookkiah
10 months ago
Modifying internal components Parameters in a Sub-System Package (QCP)
Hi I followed the instructions in online documents and youtube videos on how to add run_system_script for modifying internal components Parameters of a Sub-System Package (QCP) but so far I am not able to successfully modify it. I m hitting two main issues
1. "No Parameter Found" error when loading the QCP in QSYS. I am using internal parameter name but the system is not able to find it
2. load_component and save_component commands in the script is making the component fail to load in qsys.
Any help will be appreciated
Here is the subsystem package script
package require -exact qsys 25.1
set_package_property NAME "rpss_ssd"
set_package_property DISPLAY_NAME "rpss_ssd"
set_package_property VERSION "1.5"
set_package_property GROUP ""
set_package_property DESCRIPTION ""
set_package_property ELABORATION_CALLBACK elaboration_callback
set_package_property EXTRACTION_CALLBACK extraction_callback
set_package_property UNLOCKABLE true
add_fileset synth_fileset QUARTUS_SYNTH fileset_callback "Quartus Synthesis Fileset"
add_fileset sim_verilog_fileset SIM_VERILOG fileset_callback "Simulation Verilog Fileset"
proc elaboration_callback {} {
enable_all_instances
run_system_script TEXT {
set args $__run_system_script_args_list__
set args_len [llength $args]
for {set i 0} {$i < $args_len} {incr i} {
set param [lindex $args $i]
set val [lindex $args [incr i]]
send_message "Info" "val: $val"
load_component rpss_0
set_component_parameter_value QUEUE_MEM_BASE_ADDRESS $val
save_component
auto_assign_system_base_addresses
sync_sysinfo_parameters
save_system
} [ list ADDR 0x10000 ]
# disable_instance clock_in
# disable_instance reset_in
# disable_instance rpss_0
# disable_instance rtile_dummy_0
proc extraction_callback {} {
extract_modules
proc fileset_callback { output_name } {
generate_all_instances
  • ShengN_altera's avatar
    ShengN_altera
    Seem like the generated code already has parameter QUEUE_MEM_BASE_ADDRESS?
    Sheng
    • Bala-Mookkiah's avatar
      Bala-Mookkiah
      I am not following your question. The generated code supposed to have the parameters or not?
    ShengN_altera
    The generated code should have parameters. Seems like your generated code got the parameters as well.
    Sheng
    ShengN_altera
    When you generated the .qcp file, there's one auto generated code right?
    Is that the generated code that you share?
    Possible provide the .qcp file for testing? You may send privately to my email.
    Sheng
