Modifying internal components Parameters in a Sub-System Package (QCP)
Yes, just added the if condition, I am still seeing the original error
Error: set_component_parameter_value QUEUE_MEM_BASE_ADDRESS 0x1F000: No parameter named QUEUE_MEM_BASE_ADDRESS in rpss_0.
My qcp script
proc elaboration_callback {} {
enable_all_instances
run_system_script TEXT {
package require -exact qsys 25.1
set args $__run_system_script_args_list__
set args_len [llength $args]
for {set i 0} {$i < $args_len} {incr i} {
set param [lindex $args $i]
set val [lindex $args [incr i]]
send_message "Info" "val: $val"
if {[string match $param "QUEUE_MEM_BASE_ADDRESS"]} {
load_component rpss_0
set_component_parameter_value QUEUE_MEM_BASE_ADDRESS $val
save_component
} [ list QUEUE_MEM_BASE_ADDRESS 0x1F000 ]
# disable_instance clock_in
# disable_instance reset_in
# disable_instance rpss_0
# disable_instance rtile_dummy_0
