Modifying internal components Parameters in a Sub-System Package (QCP)
Hi sstrell,
Thanks for looking into my issue and prompt response. I tried both QUEUE_MEM_BASE_ADDR vs. QUEUE_MEM_BASE_ADDRESS, but it didn't help. QUEUE_MEM_BASE_ADDRESS is the internal name, and I should use this according to the document. I attached a screenshot of the RSS_SSD QCP internals. rpss_0 is a custom IP (RTL written by me) with HDL parameters. They are configured and exported correctly, as shown in the _hw.tcl. I tried writing a similar script to existing Intel IPs in the IP catalog, and that worked. I am wondering if I need to do anything special in my custom component to configure the parameters in the qcp system.
add_parameter QUEUE_MEM_BASE_ADDRESS STD_LOGIC_VECTOR 268435456 ""
set_parameter_property QUEUE_MEM_BASE_ADDRESS DEFAULT_VALUE 268435456
set_parameter_property QUEUE_MEM_BASE_ADDRESS DISPLAY_NAME QUEUE_MEM_BASE_ADDR
set_parameter_property QUEUE_MEM_BASE_ADDRESS WIDTH 32
set_parameter_property QUEUE_MEM_BASE_ADDRESS UNITS None
set_parameter_property QUEUE_MEM_BASE_ADDRESS DESCRIPTION ""
set_parameter_property QUEUE_MEM_BASE_ADDRESS AFFECTS_GENERATION false
set_parameter_property QUEUE_MEM_BASE_ADDRESS HDL_PARAMETER true
set_parameter_property QUEUE_MEM_BASE_ADDRESS TRANSFORM_PARAMETER false
set_parameter_property QUEUE_MEM_BASE_ADDRESS EXPORT true
