8 years agoModelSim: Warning: NUMERIC_STD."=": metavalue detected, returning FALSE
Hi, I'm having trouble with a testbench I wrote. When I include a particular 'if' statement, the design compiles/synths, then I run the functional simulation in modelsim, and get: Warning:...
8 years ago --- Quote Start --- Yes, this will likely be signals inside the design being uninitialised, and fairly normal. So normal and annoying, there is an option to turn warnings like these from numeric_std off. Simulation -> runtime options -> "suppress warnings" from Synopsys Packages (from std_logic_unsigned/arith) From IEEE packages (numeric_std) If you're running from a script, set these variables before the run command:
set StdArithNoWarnings 1
set NumericStdNoWarnings 1
--- Quote End --- Thanks for the help. It was not the warnings that bothered me but that I assumed they were stopping my waveform from generating. Actually it was something unrelated - in the code I pasted, there is a possibility for no time to run at all, as there's no wait statement. Moving onto the next state was dependent on x cycles occurring, so this broke the entire simulation and I assumed it was the warnings. Fixed now - thanks for telling me about the warnings commands.
