14 years ago
Modelsim redirect output stream of a macro
In Modelsim Altera Starter Edition,
Is there a way to redirect output stream of a macro file to a file ?
I use "mymacro.do" to display what_i_want_in_the_console.
I would like to parse the ouput stream to a file.
My searches in document, alteraforum and web didn't give anything.
    Using the command-line version of vsim, you can redirect the output to a file. Eg., something like
    vsim -c testbench -do "run -a; q" &> testbench.log
    Cheers
    Dave
    Hi, thanks for answer,
    vsim -c myentity -do mymacro.do &> mymacro.log
    But vsim command doesn't like &> mymacro.log. It would like to take this as an entity.
    So solution not found yet...
    I found a workaround : write the transcript window to a file
    write transcript myfile.log
    --- Quote Start ---
    --- Quote End ---
    Were you trying this from a bash shell? I commented that this format was for the command-line version of vsim, not the GUI version.
    I use this method in Makefiles to generate logfiles from failing testbenches.
    Cheers,
    Dave
    Here's the Makefile section:
    #  -----------------------------------------------------------------#  Check target#  -----------------------------------------------------------------# #  Change into the control_test build directory so that the#  exitstatus and log files are generated in the control_test#  directory. 'make clean' will then remove that directory.# #  The logic to test the exit code could be transformed into#  a bash script that takes the executable as the argument.#  Eg. check_exit_status $testbench# #  Each testbench should have the generic makecheck, with a default#  of 0. The makefile sets the parameter to 1. The exitstatus file#  will not be created when makecheck = 0.#
    .PHONY: check
    check: $(CONTROL_TEST_LIB_DONE)
        @cd $(CONTROL_TEST_DIR);
        rm -f exitstatus;
        for check in $(control_test_CHECKS); do
            echo -n "TEST: $$check";
            $(VSIM) $(VSIM_ARGS) -c control_test.$$check -gmakecheck=1
            -do "run -a; q" &> $$check.log;
            if ; then
                if ; then
                    echo -e "\rFAIL: $$check (see $$check.log)";
                    rm exitstatus;
                    exit 1;
                else
                    echo -e "\rPASS: $$check";
                    rm exitstatus;
                fi;
            else
                echo -e "\rFAIL: $$check. `pwd`/exitstatus file not found. Check the testbench.";
                exit 1;
            fi;
        done
