Altera_ForumHonored Contributor14 years agoModelsim redirect output stream of a macro In Modelsim Altera Starter Edition, Is there a way to redirect output stream of a macro file to a file ? I use "mymacro.do" to display what_i_want_in_the_console. I would like to parse the...Show More
Altera_ForumHonored Contributor14 years agoI found a workaround : write the transcript window to a file write transcript myfile.log
Recent Discussionsaltera scfifo ip with power-up initial valueAltera SSLC Licenseagilex7 ram back-annotationFIR IP configured for InterpolationSSLC Login Issue – "You need to enroll" loop after OTP verification
