17 years ago
Modelsim PE 6.5a Issue
I have been driven round the bend with a problem I am experiencing with Modelsim. I am trying to to a functional simulation of a design and I believe I am having problems with the libraries.
I am using a Cyclone III device that has a few megafunctions included (PLL, ROM:1 port, altclkctra).
In modelsim I have mounted the relevant libraries (altera, altera_mf and cycloneiii libraries) using the commands from a script I found on a previous post here. They seemed to compile ok and it seems modelsim recognises the compiled libraries.
Anyway when I run the design with the PLL instantiated, the output of the PLL is undefined. I dont recieve any warning in Quartus and I don´t think it is a problem in my design. I have double checked everything and can´t see any problems. In the Modelsim transcript window I recieve the following messages:
<attachment 1>
I dont understand what the INTERNAL ERROR: pkgref: export lookup failed means. I havent been able to find any real info on this online. Is this warning an issue? Various other messages are output as can be seen, but I don´t think any of them are serious (but please put me right on this if I am overlooking something). It also says that Cyclone III PLL was reset (as the testbench should do) so I don´t understand what the problem might be.
If I remove the PLL from the deisgn and just leave the remaining megafunction instatiated with code (ROM1 ports and altclkctra) I recieve a fatal error when I try to start the simulation. The following messages are presented to me on the transcript window.
<attachment 2>
I do not understand the nature of the fatal error, as the cyclone iii_atoms.vhd llibrary seems to be properly compiled and recognised by quartus.
Is it nessesery to modify the modelsim .ini file after compiling new libraries? I have tried this by placing in the following commands for the libraries which are mapped in the same directory:
cycloneiii = cycloneiii
alter = altera
altera_mf = altera_mf
Anyway this made no difference.
Please let me know if I have done something dumb or have overlooked something.
Many thanks for any help.
EDIT: I also forgot to say that I only experience these problems with a megafunction instantiated. When I simulate only my VHDL code, I do not have any such problems. This is what leads to to believe it is a library issue. Also I am using Quartus v9 and compiled the librraies from its eda_lib directory.
1 Reply
    Hi again,
    Problem solved. I was playing around with a version of modelsim altera with the same project as the licence for PE was in use by another workmate. This seems to somehow effect or corrupt something in PE.
    Anyway I uninstalled both versions of modelsim and re installed PE again. It seems that some files on the PE version got corrupted somehow, but after reinstalling it and recompiling the libraries in the same way it now works fine.
