Modelsim not launching
I have encountered a problem with Modelsim Intel-FPGA starter edition 10.5b. When i try to run the RTL-simulation tool, modelsim won't open
I get these messages:
Info (22036): Successfully launched NativeLink simulation (quartus_sh -t "c:/intelfpga_lite/18.1/quartus/common/tcl/internal/nativelink/qnativesim.tcl" --rtl_sim "Lab3" "Lab3_tolo")
and
Info (22036): For messages from NativeLink execution see the NativeLink log file C:/Users/leont/OneDrive/Dokumenter/2. semester/Digitalteknikk (ELPE1400)/Lab 3/Lab3_nativelink_simulation.rpt
I have specified the path in EDA tool options as:
C:\intelFPGA_lite\18.1\modelsim_ase\win32aloem
I have tried many solutions from the internet, but yet not fixed it. Thanks for any help
- ShengN_altera
- Leon5
I have tried to re-install on the same location but it didn't fix the problem, is there any other possible solutions?
- ShengN_altera
Make sure un-install first and totally delete the file folder as well as the modelsim.ini.
Then re-install again.
Sheng
- Leon5
Hi, i tried that as well, without any luck. Is it possible that my wi-fi can prevent modelsim to launch. Because when i used a public wi-fi, it worked. But not on my private wi-fi?
Thanks for any help.
- ShengN_altera
Probably that's the case. Your private wi-fi prevent some of the .exe from being running. Firewall, anti-spyware, and anti-virus settings will cause same problem as well.
Sheng
- Leon5
I have tried to deactivate my firewall, ani-spyware, and anti-virus setting. And that didnt work also. Any more tips?
- ShengN_altera
Then probably have to use other wifi instead of the private wi-fi. May be there's something is blocking when using private-wifi.
