18 years ago
ModelSim Newbie
Hello All,
I've just started learning Verilog and as a part of the process i decided to test the testbenches with Verilog PE Student Edition 6.4 .
When i compile a verilog file ,it compiles without any error but i have no object file after that! How can i simulate the code?
__________________________________________________________________
module stimcrct;
reg A,B,C;
wire x,y;
circuit_with_delay cwd(A,B,C,x,y);
initial
begin
A = 1'b0 ; B = 1'b0 ; C = 1'b0;
# 100
A = 1'b1 ; B = 1'b1 ; C = 1'b1;
# 100 $finish;
end
endmodule
module circuit_with_delay (A,B,C,x,y);
input A,B,C;
output x,y;
wire e;
and# (30) g1(e,A,B);
or # (20) g3(x,e,y);
not# (10) g2(y,C);
endmodule
Please HELP !!!
Best Regards
    --- Quote Start ---
    So you are not using QuartusII for your compilation?
    --- Quote End ---
    No. I've only started learning Verilog.
    ModelSim has tutorials, they offer an effective way to learn the operation to my opinion.
    When you compile your Verilog design in ModelSim (using the vlog command), it will create a work library that you will need to simulate from using the vsim command.
    You can refer to the user guides that came with your installation on how to do this.
    Modelsim has a graphical user interface for a lot of things but I prefer using script files like this:
    vlib work
    vlog ../hdl/file1.v
    vlog ../hdl/file2.v
    vsim -L <library_name> -do wave_all.do work.top
    log -r /*
    run -all
    whereas wave_all.do is the wave file generated with the waveform view.
    The script is then run from the ModelSim console with
    do <scriptfilename>, i.e. do test_all.do
