NGord
2 years agoModelsim Lite Quartus 18.1 - simulating ROM
When simulating a ROM component within the testbench file (for generating a data packet) I get the Modelsim warning # ** Warning: (vsim-3473) Component instance "inst_altera_testbench_packet_rom : ...
ShengN_altera
2 years agoHi,
I try to run the tb.tcl using modelsim ase from my side without any problem. Check attachments. May be that's bad installation of modelsim try to re-install again.
Sheng
- NGord2 years ago
Now this is weird - I tried that it still didnt work.
I even downloaded the Modelsim Starter from Quartus 20.1 - same version as you, but i get same fault.
See attached transcript.Looks like you are running Linux and I am running Windows 10. Do you have a Windows machine?
I f I were to try and learn Questa - it looks like I would need a license.
- NGord2 years ago
Tried another laptop, Windows 10, same failure.
