NGord
2 years agoModelsim Lite Quartus 18.1 - simulating ROM
When simulating a ROM component within the testbench file (for generating a data packet) I get the Modelsim warning # ** Warning: (vsim-3473) Component instance "inst_altera_testbench_packet_rom : ...
ShengN_altera
2 years agoHi,
I try the ROM-1 Port IP on both hex and mif files without any problem. Check the attached design file and screenshot inside. May be try with that attached design file and see got any problem or not?
Sheng
NGord
2 years agoYours works even with Quartus 18.1 which is what I am using.
The difference has to be I have a VHDL project and my ROM is part of the testbench file.
I have to use a tcl script file to persuade Modelsim to compile the ROM first because of that.(tb.tcl)
The issue has to be the vsim command or the fact I am using a MAX10.
I attach my project.
