ISupp6's avatar
ISupp6
7 years ago
ModelSim license not showing as available in FlexLM.
FlexLM version 11.16.2.1 build 245043 x64_n6
The one error that I see in the log is around Feature alteramtivsim (which may be ModelSim
"alteramtivsim" v2020.08, vendor: mgcld, expiry: 20-aug-2020
vendor_string: 0D5FFAC5
License server: licensealt01
floating license starts: 21-aug-2019, expires: 20-aug-2020
This license cannot be checked out because:
No such feature exists.
Feature: alteramtivsim
License path: C:\Program Files (x86)\Altera\flexlm\license.dat;
FlexNet Licensing error:-5,147
Other licenses show as available to checkout, but not ModelSim
  • AR_A_Intel's avatar
    AR_A_Intel
    Hello
    Welcome to INTEL forum. To narrow down this issue. Can you provide your
    1) Debug.log file
    3) Error message screen shot
    5) Machine OS information
    6) Quartus version used
    7) License.dat file
    And for privacy, you can also reply/attach your file in private message.
    • ISupp6's avatar
      ISupp6
      Sent all via PM.
      Thank you.
    • ISupp6's avatar
      ISupp6
      Any update here? There have been a couple email communications, but that has stopped. Our engineers are anxious to begin using this.
  • ISupp6's avatar
    ISupp6
    Now I see the following in Server Status:
    Status
    Flexible License Manager status on Thu 8/29/2019 21:18
    [Detecting lmgrd processes...]
    License server status: 29000@licensealt01
    License file(s) on licensealt01: C:\Program Files (x86)\Altera\flexlm\license.dat:
    licensealt01: license server UP (MASTER) v11.16.2
    Vendor daemon status (on licensealt01):
    alterad: UP v11.16.2
    Feature usage info:
    Users of 6AF7_0116: (Total of 1 license issued; Total of 0 licenses in use)
    Users of ip_base: (Total of 7 licenses issued; Total of 0 licenses in use)
    Users of 6AF7_010C: (Total of 1 license issued; Total of 0 licenses in use)
    Users of maxplus2: (Total of 7 licenses issued; Total of 0 licenses in use)
    Users of maxplus2verilog: (Total of 7 licenses issued; Total of 0 licenses in use)
    Users of maxplus2vhdl: (Total of 7 licenses issued; Total of 0 licenses in use)
    Users of quartus_nonvolatile_encryption: (Total of 7 licenses issued; Total of 0 licenses in use)
    Users of quartus: (Total of 7 licenses issued; Total of 0 licenses in use)
    Users of 6AF7_00D8: (Total of 7 licenses issued; Total of 0 licenses in use)
    Users of 6AF7_0014: (Total of 7 licenses issued; Total of 0 licenses in use)
    Users of 6AF7_0034: (Total of 7 licenses issued; Total of 0 licenses in use)
    mgcld: The desired vendor daemon is down.
    Check the lmgrd log file, or try lmreread.
    Feature: mgcvipae
    Vendor:Host: licensealt01
    License path: 29000@licensealt01;
    FlexNet Licensing error:-97,121
  • ISupp6's avatar
    ISupp6
    Actually, even though I restarted the service, that did not help, but a reboot seemed to help. I am now seeing the below. I will have an engineer test to see if they can check out a license in the morning.
    Status
    Flexible License Manager status on Thu 8/29/2019 21:25
    Feature usage info:
    mgcld: UP v11.11
    Feature usage info:
    Users of mgcvipae: (Total of 8 licenses issued; Total of 0 licenses in use)
    Users of mgcvipaeaxi: (Total of 16 licenses issued; Total of 0 licenses in use)
    Users of mgcvipaeaxi4: (Total of 8 licenses issued; Total of 0 licenses in use)
    Users of alteramtivsim: (Total of 5 licenses issued; Total of 0 licenses in use)
  • ISupp6's avatar
    ISupp6
    And latest update from engineer:
    I can start the Modelsim UI (non-student version), and it appears to compile the code, but when I try running the simulation, it tells me the following features can't be found:
    alteramtivlog
    alteramtivsim
    In status as last posted, we can clearly see that 2nd license is available, but not the alteramtivlog
    AR_A_Intel
    Hi Sir
    Could you provide the latest debug.log file for checking? reply/attach your file in private message.
    • ISupp6's avatar
      ISupp6
      Well, I had replaced this previously and restarted the service, but apparently it needed a server reboot. All seems to be working now.
      I am glad we got to resolution, but this is something that could have been resolved in a brief call or web session instead of 10 days of back and forth while our engineers sat idle. I really wish Intel would reconsider their support model. Forums serve a purpose, but when you have paid support ....
