junyoung2
1 year agoModelsim.ini setting
Hello, I learned about a setting called vlog while searching for bit width mismatch. I confirmed that if you set anything in the folder called Modelsim.ini, it will alert you when bit width does not...
KennyT_altera
1 year agoI have attempt to find some setting in the Questasim/Modelsim user guide, there are no option for this.
What I would suggest you is to go to EDA/Mentor Graphic forum to ask this question as this question is more related to them.
