Charger0025's avatar
Charger0025
2 years ago
ModelSim executable not found in C:/intelFPGA_lite/simulation/modelsim Error.
I am having this error message when attempting to run the model sim execution in the University Program VWF.
My OS is windows 10, i5 processor. I am running the 23.1 software version. I am using the MAX10 10M50DAF484C7G device (DE10-Lite).
from the reading that have done I need to go to tools, Options, EDA Tool Options, under the model sim tab I need to point it to the correct directory. When I search I have assigned the following directory:
I get to the modelsim folder and there are no further folders to go into, I have removed and reinstalled the software and I am having the same issue.
What am I missing and how can I fix it?
  • newbieengie's avatar
    newbieengie
    I just make an account just to share this
    randomly found it
    even though it has been 2 years i think that you've already found the solution
    install modelsim and make this folder as the directory modelsim_ase\win32aloem
  • SyafieqS's avatar
    SyafieqS
    I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
  • Charger0025's avatar
    Charger0025
    I have attempted to run the simulation the following ways and I am still receiving an error message. Can you explain further what you mean since there is still a persisting error?
  • sstrell's avatar
    sstrell
    The directory should be qsim (for Questasim), not modelsim, just as shown in the window. Questasim replaced Modelsim in Quartus about 2 or 3 years ago, so if you're using 23.1, it should be qsim or questasim in the path, not modelsim.
