17 years agoModelsim error: UDP ports cannot be connected by name
Hi all,
When I try to simulate the example of link_port downloaded from altera website, the error in the title appears. The following is the error message copied from the transcript windows of Modelsim:# Loading E:/508/fpga/sim/altera_mf.dffep# ** Fatal: (vsim-3367) E:/508/fpga/sim/altddio_out.v(84): UDP ports cannot be connected by name.# Time: 0 ns Iteration: 0 Instance: /data_order/lt0/lp_tx_data_3/genblk1 File: E:/508/fpga/sim/altddio_out.v# FATAL ERROR while loading design# Error loading design According to the error message, I have examined the port connections. The component "altera_mf.dffep" is instantiated with correct names in the file "altddio_out.v". So i can't fix this problem:(. what can i do next? The two files: "altera_mf.dffep" and "altddio_out.v" are required when the files "lp_rx.v" and "lp_tx.v" are compiled. Thanks a lot!
