8 years agomodelsim clock network stuck StX (gate level sim)
Hi All, I'm hoping someone can help with an issue I've observed in modelsim (10.5b, quartus 17.0). Simply put the clock network correctly drives the network right up to the point where it ...
8 years ago --- Quote Start --- I will initialise d_reg to known value to keep modelsim happy --- Quote End --- Hi, Original code (before I stripped it down to bare minimum) had a sync reset for d_reg and still exhibited the same behavior. Added initial power on state ("= '0;") and it still did the same thing. In all three cases (reset, power on state, and the above code) the simulator shows the register output settling to '0' within a few ns of the simulation. I forgot to mention that the RTL simulation works as expected. Even if I totally stuffed up timing closure I'd still expect the clock to the driven... Any other ideas? -- Paul
