adjusting font scaling to -1120 px per 11 inches gives giant fonts in modelsim 10.4d source window, without any of the library tricks described earlier.. this is huge.. :3
Note: please do not replicate this, it seems to break the modelsim interface permanently :( need to find the control file to readjust the font scaling option. - Altera_Forum
I don't think tcl/tk font scale accept a negative value. please confirm manual.
As for the control file, according to the modelsim command manual, they might be .modelsim or modelsim.ini. pref.tcl might be possible, I think. As for the negative font size specifying, I found the behavior has been quite strange via editing the preference menu(by name). So I recommend editing default textfont size of $HOME/.modelsim file to the negative value(such as -12 or -10), and don't touch. I think you can specify any fixed font as you wish. I'm going to test these settings. My environment is Ubuntu16.04_64 and CentOS7.2_64. On CentOS, all defualt fonts were specified by negative value at first, but preference menu does not show negative value on the menu. The behavior is slightly strange. I guess this is also some trick by Altera or Mentor. That's why I think it might be no use to reinstall fonts or libraries. - Altera_Forum
do you find ?
I guess default scale initialize file might be 'screenscalesV2' of $HOME/.modelsim, because my screen setting exists only there. the scale value syntax might be, host-name:0.0 {pixels-point inch pixel} here, pixels-point is tk scaling factor of pixels/point. it's around 1(me, 1.3546). I'm not sure how they calculate it. - Altera_Forum
I am using Quartus Prime Version 15.1.2 Build 193 02/01/2016 SJ Standard Edition (as well as Quartus 13.1) on Windows 10. I am having issues with the GUI. Some buttons are too small for the writing inside to be readable. For example, in Qsys, every elements in the lists under "IP Catalog>Project", "IP Catalog>Library" as well as the lists under "Hierarchy" are overlapping each other and therefore unreadable. Also, when I select an IP from the IP catalog, the font is too small to be readable. Can you help me to figure out which settings I have to change? Thank you very much for your help. - Altera_Forum
I also installed Quartus16 on win10_64, and I don't find out any Qsys overlapping font problem now.
I mainly use linux sorry. I'm not familiar with windows. However, I found out I didn't have IP catalog dialog in Quartus16 :( I have to look into them well. I didn't find out any option menu to customize font in Qsys. It also look like tcl/tk app, but ... - Altera_Forum
I ran into this too in Ubuntu 16.04 LTS with modelsim 10.5 ASE. I fixed it as follows :
1. Open ~/.modelsim 2. Find: PrefDefault = ... textFontV2 {Verdana 12} 3. Change 12 to -12, so it will looks like this: textFontV2 {Verdana -12} 4. Save ~/.modelsim 5. Reopen modelsim
