10 years agomodelsim ase 10.4d/quartus lite 16.0,15.1 on linux source font problem
I can't read vhdl/verilog source because of too small font around 1pt. tools->edit preference->source windows->fixed font or text font size setting change was no effect. This problem is same aft...
10 years agoHi,
I am using Quartus Prime Version 15.1.2 Build 193 02/01/2016 SJ Standard Edition (as well as Quartus 13.1) on Windows 10. I am having issues with the GUI. Some buttons are too small for the writing inside to be readable. For example, in Qsys, every elements in the lists under "IP Catalog>Project", "IP Catalog>Library" as well as the lists under "Hierarchy" are overlapping each other and therefore unreadable. Also, when I select an IP from the IP catalog, the font is too small to be readable. Can you help me to figure out which settings I have to change? Thank you very much for your help.
