XXiao2
6 years agomodelsim Altera support for vpi and dpi
I am trying to use DPI feature and started with one simple DPI project. I can compile the code (.sv and .c) successfully but when i want to simulated the design. I got the error message: # Model Tec...
SyafieqS
6 years agoHi,
According to link below, the QUARTUS_LIBRARY_PATHS environment variable specifies user-defined library paths. You can use this environment variable to define multiple library paths at the same time, instead of individually adding each path to the user library.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf (p14-QUARTUS_LIBRARY_PATHS )
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/archives/quartus_install-16.1.pdf (p14-Configuring the Linux User Environment)
- XXiao26 years ago
Hi there, Thank you for your reply. The tool I am talking about is the modelsim not the Quartus. Can you be more specific about the setting of this environment variable to solve this issue. Frank
