18 years ago
Modelsim & VHDL Configuration
It seems that Modelsim doesn't support VHDL Configuration feature.
One of my module contain two architectures, in the top level VHDL file use VHDL configuration to use the two different architectures.
During modelsum pre-simulation, it seems to always use the last architecture.
Anything mistake?
Thanks for any response.
    You defined this as a custom component? Did you add the configuration file to the list of HDL files for the custom component? If not, you'll need to add the file containing the configuration to your Quartus II project.
    I'm no SOPC Builder expert so take anything I say with a grain of salt. :)
    The configuration declaration is in the same file of the HDL file which contain one entity and two architectures associated with the entity. It has been added to the list of HDL files for the custom component.
    I can compile the whole quartusII project without error, so it maybe a bug of SOPC Builder.
