[Modelsim > Execute tcl (.do) macro] How to get the location of the currently running script
- 2 years ago
I wanted to try to avoid the user having to manually input via text a file path to the script to source it in the console window. The "Tools > tcl > Execute Macro" option was very convenient. It worked IF I did "File > Change Directory", but I wanted a way without making the user have to do that either.
I found a way to do what I wanted:
set script_frame [info frame [ expr [info frame] - 1]] set my_cmd [dict get $script_frame cmd] set src_dir [ file dirname [ file normalize [ string range $my_cmd 3 end ] ] ] cd $src_dir cd ../lite_project/simulation/modelsim- "Info frame" lists the number of frames (it was 12 for me)
- "Info frame 11" (the one before the last frame) contained the "do" command for my script
- So I had to just pull out the path from the "do" command with "string range", and I got my path.
Now it works right immediately on startup of ModelSim and the script runs perfectly.
Ryan
Ryan
