ModelSim - vector input not showing the correct binary
Please see the attached file. It's a 10's complement for 4-bit BCD.
I have a 4-bit vector input, and 4-bit vector output. But, the vector input is not showing the correct binary number. It shows all 0000, although the waveform show the correct input that I key in.
How to display the correct vector input in this "Wave" window?
- sstrell
There's something wrong with that group in the Wave view. As you can see in the Objects pane, D is correct there. Remove what you have in the Wave view and then click and drag D from the Objects pane to the Wave view.
#iwork4intel
- LChow3
Thanks for suggestion.
First, I couldn't load / open the wave that I saved yesterday. How do I open the wave (those inputs signals that I put in earlier)?
I have saved the wave in .do file.
- LChow3
If I delete D, drag D from Object pane to Wave window, I couldn't key in the D binary values.
- RichardT_altera
Do you mean to provide input stimulus? If so, you can right click the D in the wave window, select force and insert value. Then run simulation.
Insert one by one will become a tedious job, instead you can insert example line in the transcript.
VSIM> force -deposit /D 2#0, 2#1 20, 2#0 40, 2#1 60, 2#1 80
VSIM> run 200 ns
the line change D to binary value 0 (2#0) starting from time instant now. Then, 20 ns later, change the input to 1 (2#1 20).
- RichardT_altera
Insert "do example.do " in the modelsim transcript.
- LChow3
Got it, thank you.
