12 years ago
mixed HDL simulation model
I have a design in multi HDL languages. I use Quartus 13.0 wnd my target device is Cyclone V
When I generate a build with QSYS, it generates Verilog and VHDL files for different IPs in synthesize folder.
I try to make simulation model. For now everything is VHDL except a_block. I selected option VHDL for “create simulation model” in generation tab of QSYS and I see this error for a_block IP in QSYS:
Error: a_block: a_block does not support generation for VHDL Simulation. Generation is available for: Quartus Synthesis, Verilog Simulation.
I did a little bit of research and found that there is a setting to generate simulation model in VHDL. I added this setting in tcl of a_block IP:
set_module_property simulationModelInVHDL “true”
I got the same error! any idea on this?
1 Reply
