annamalairaj's avatar
annamalairaj
10 months ago
Minimum pulse width violation on EMIF-HPS
We are observing Minimum pulse width summary violation on three clocks in EMIF. Snapshots of Minimum pulse width violation on each of these clocks are attached.
Quartus version: 25.1.1
targeted FPGA: AGFB027R24C2E3V
Please share your suggestions.
  • Hi AdzimZM_Altera​
    I have used Superior Performance with Maximum Placement Effort performance option and also tried the EMIF document optimize timing method by updating the Placement Effort Multiplier to 2 still same violation is observed.
    I have also attached the HPS subsystem files.
    • AdzimZM_Altera's avatar
      AdzimZM_Altera
      hi annamalairaj
      I make hps_subsys as a top level, set the hps bridge as virtual pin and compile the design.
      I don't get the timing violation as you see.
      Can you try that from your end?
    • annamalairaj's avatar
      annamalairaj
      Hi AdzimZM_Altera​
      Sorry for the delayed response, and thanks for your patience. I wasn't able to follow up earlier. Regarding your questions:
      1. Can you share the connection of the EMIF HPS IP in Platform Designer?
        • Attached the image (emif_hps.png).
      2. What is the clock frequency you set in EMIF HPS IP?
        • 1200 MHz
      3. Is there any SDC has been set to target this clock?
        • No.
      4. Is there any other IP than EMIF HPS IP in IO Bank 3C and 3D?
        • No, IO Bank 3C and 3D are dedicated only for EMIF HPS IP.
      5. Are you sharing the reference clock source for EMIF HPS IP?
        • No, we are not sharing this clock with any other blocks.
    AdzimZM_Altera
    I have a few questions below, please help to provide your feedback.
    Adzim
