12 years agoMetastability avoidance...again!
Hi folks,
I have an ADC which provides LVDS data to the FPGA (cyclone 3). The data clock is fed to a dedicated LVDS mega-function, as is the serial data. I have a frame clock that also comes from the ADC to the FPGA, the frame clock is used to latch the data into registers. The data leaving the LVDS mega-function is therefore synchronous to the ADC data clock only. This implies that I will need to synchronize the de-serialized data to the sysclk (400MHz) along with the frame clock to ensure I avoid meta-stability between the ADC clock domain and the sysclk domain. Is this correct, I only ask because the de-serialized data is 4 channels of 10 bit data (40bit in total), and to sync in the normal way by using 3 stage FFs clocked by sysclk is going to cost me some serious logic space in a cyclone 3. AM i on the right track? Thanks in advance... D
