MegaWizard Plug in Manager GUI ipdate for Windows 11
I don't understand some comments. Megawizard window is opened in most recent Quartus 24.1 Std/lite when you e.g. click RAM: 1-PORT in IP catalog. So no matter if it's possibly planned to be obsoleted, it's part of present Quartus GUI.
I however don't see an actual problem here. @mevenson is apparently complaining about default window layout after opening Megawizard. The behaviour isn't specific to Windows 11. Window size is a few percent below full size for RAM IP, but you can enlargen it easily. Initial window layout may look different depending on display resolution and character size, it's probably not tested with all possible resolutions.
I remember cases where you had difficulties to reach necessary buttons at all, but not with recent Quartus versions.
Frank
