8 years agoMegaWizard Plug-In Manager didn't generate the .bsf file of IPCore
Hi, everyone. I encountered a wierd trouble. When I try to add a IPCore into the Block Diagram and generate an IP Core using MegaWizard Plug-In Manager, I got the following warning after the gen...
8 years agoHi,
I have tried to recreate the warning but it successful to generated .bsf without warning used quartus 13.1 win10. Which version of quartus are you using(13.3!)? 1.Regenerate and check if mega-wizard terminated in between process before generating the file? 2.Have you checked in project directory for .bsf file?If it is not generated Try by deleting incremental_db and db folder or create new project and check. or Different version of quartus. Let me know if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- SDefa6 years ago
I have the same problem with ALTMULT_COMPLEX that can't create the .bsd file. But others MegaCore function like ATLSQRT creates it. Is there a reason why? I tried Quartus 17.0, 17.1, 19.1. I normally install Quartus in D:\intelFPGA\ but I also tried with c:\intelFPGA to see if it was the SW path.
There is no space in my project path... it was D:\testing\
Any clues?
Simon
