9 years agoMegaWizard 2x8k Dual Port Memory
Try to Convert a Project to Cyclone III but need Help with the Memory Type
Orginal Codemodule vidram(
output data_out, // cpu interface input data_in,
input cpu_addr,
input we,
output video_data, // video hardware intf
input video_addr,
input clk
// A single Spartan 8x2k 2-port RAM. Easy.
RAMB16_S9_S9
ram(.DIA(data_in),
.DIPA(1'b0),
.DOA(data_out),
.DOPA(),
.ADDRA(cpu_addr),
.WEA(we),
.ENA(1'b1),
.SSRA(1'b0),
.CLKA(~clk), // see description
.DIB(8'h00),
.DIPB(1'b0),
.DOB(video_data),
.DOPB(),
.ADDRB(video_addr),
.WEB(1'b0),
.ENB(1'b1),
.SSRB(1'b0),
.CLKB(~clk) // see description
endmodule // vidram
Mega Wizard generates me module vidram ( clock,
data,
rdaddress,
wraddress,
wren,
q);
input clock;
input data;
input rdaddress;
input wraddress;
input wren;
output q;
`ifndef ALTERA_RESERVED_QIS
// synopsys translate_off
`endif
tri1 clock;
tri0 wren;
// synopsys translate_on
`endif
wire sub_wire0;
wire q = sub_wire0;
altsyncram altsyncram_component (
.address_a (wraddress),
.clock0 (clock),
.data_a (data),
.wren_a (wren),
.address_b (rdaddress),
.q_b (sub_wire0),
.aclr0 (1'b0),
.aclr1 (1'b0),
.addressstall_a (1'b0),
.addressstall_b (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clock1 (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.data_b ({8{1'b1}}),
.eccstatus (),
.q_a (),
.rden_a (1'b1),
.rden_b (1'b1),
.wren_b (1'b0));
defparam
altsyncram_component.address_aclr_b = "NONE",
altsyncram_component.address_reg_b = "CLOCK0",
altsyncram_component.clock_enable_input_a = "BYPASS",
altsyncram_component.clock_enable_input_b = "BYPASS",
altsyncram_component.clock_enable_output_b = "BYPASS",
altsyncram_component.intended_device_family = "Cyclone III",
altsyncram_component.lpm_type = "altsyncram",
altsyncram_component.numwords_a = 2048,
altsyncram_component.numwords_b = 2048,
altsyncram_component.operation_mode = "DUAL_PORT",
altsyncram_component.outdata_aclr_b = "NONE",
altsyncram_component.outdata_reg_b = "CLOCK0",
altsyncram_component.power_up_uninitialized = "FALSE",
altsyncram_component.read_during_write_mode_mixed_ports = "DONT_CARE",
altsyncram_component.widthad_a = 11,
altsyncram_component.widthad_b = 11,
altsyncram_component.width_a = 8,
altsyncram_component.width_b = 8,
altsyncram_component.width_byteena_a = 1;
endmodule but i need 2 Output Lines4 Replies
You need to select "two read/write ports" on the very first MegaWizard page.
I had this idea already, but how do I have to assign
orginal
changed tomodule vidrama( output data_out, // cpu interface input data_in, input cpu_addr, input we, output video_data, // video hardware intf input video_addr, input clk ); .... vidrama vidram( .data_out(vram_data), .data_in(data_in), .cpu_addr(addr), .we(vram_we), .video_addr(video_addr), .video_data(video_data), .clk(clk) );
will not workmodule vidrama ( address_a,//cpu_addr, address_b,//video_addr, clock,//clk data_a,//data_in, data_b,//data_in, wren_a,//we, wren_b,//we, q_a,//data_out, q_b//video_data, ); ..... vidrama vidram( .data_a(data_in), .data_b(data_in), .address_a,(addr), .address_b,(video_addr), .wren_a(vram_we), .wren_b(vram_we), .q_a(vram_data), .q_b(video_data), .clock(clk) ); - Altera_Forum
--- Quote Start --- will not work --- Quote End --- No, why don't you copy the original port assignment, e.g. disable wren_b? - Altera_Forum
Sorry for German but my English is very Bad.
Kannst du vielleicht bitte mal drüber schauen und mir den Weg zeigen ich bekomm es nicht hin Original Files http://www.share-online.biz/dl/wmw069hot6m
