13 years agoMegafunction wizard VHDL error?
Hello, I am currently working on a processor project for school, and have run into an issue where one of the megafunction-generated VHDL files seems to have an error in it, and I was wondering if anyone on here could help figure out what is causing it. I dont really know much VHDL, so I was wondering if someone could explain to me why this isnt working. Also, I have not edited the VHDL file at all. Any help would be great!
Error: Text Design File syntax error: Text Design File contains MEMORY where a symbolic name or a number was expected VHDL File: -- megafunction wizard: %RAM: 1-PORT% -- GENERATION: STANDARD -- VERSION: WM1.0 -- MODULE: lpm_ram_dq -- ============================================================ -- File Name: Memory.tdf -- Megafunction Name(s): -- lpm_ram_dq -- -- Simulation Library Files(s): -- lpm -- ============================================================ -- ************************************************************ -- THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE! -- -- 8.0 Build 215 05/29/2008 SJ Full Version -- ************************************************************ --Copyright (C) 1991-2008 Altera Corporation --Your use of Altera Corporation's design tools, logic functions --and other software and tools, and its AMPP partner logic --functions, and any output files from any of the foregoing --(including device programming or simulation files), and any --associated documentation or information are expressly subject --to the terms and conditions of the Altera Program License --Subscription Agreement, Altera MegaCore Function License --Agreement, or other applicable license agreement, including, --without limitation, that your use is for the sole purpose of --programming logic devices manufactured by Altera and sold by --Altera or its authorized distributors. Please refer to the --applicable agreement for further details. INCLUDE "lpm_ram_dq.inc"; SUBDESIGN Memory ( address[7..0] : INPUT; data[7..0] : INPUT; inclock : INPUT; we : INPUT = VCC; q[7..0] : OUTPUT; ) VARIABLE lpm_ram_dq_component : lpm_ram_dq WITH ( LPM_ADDRESS_CONTROL = "REGISTERED", LPM_INDATA = "REGISTERED", LPM_OUTDATA = "UNREGISTERED", LPM_TYPE = "LPM_RAM_DQ", LPM_WIDTH = 8, LPM_WIDTHAD = 8 ); BEGIN q[7..0] = lpm_ram_dq_component.q[7..0]; lpm_ram_dq_component.address[7..0] = address[7..0]; lpm_ram_dq_component.inclock = inclock; lpm_ram_dq_component.data[7..0] = data[7..0]; lpm_ram_dq_component.we = we; END; -- ============================================================ -- CNX file retrieval info -- ============================================================ -- Retrieval info: PRIVATE: ADDRESSSTALL_A NUMERIC "0" -- Retrieval info: PRIVATE: AclrAddr NUMERIC "0" -- Retrieval info: PRIVATE: AclrByte NUMERIC "0" -- Retrieval info: PRIVATE: AclrData NUMERIC "0" -- Retrieval info: PRIVATE: AclrOutput NUMERIC "0" -- Retrieval info: PRIVATE: BYTE_ENABLE NUMERIC "0" -- Retrieval info: PRIVATE: BYTE_SIZE NUMERIC "8" -- Retrieval info: PRIVATE: BlankMemory NUMERIC "1" -- Retrieval info: PRIVATE: CLOCK_ENABLE_INPUT_A NUMERIC "0" -- Retrieval info: PRIVATE: CLOCK_ENABLE_OUTPUT_A NUMERIC "0" -- Retrieval info: PRIVATE: Clken NUMERIC "0" -- Retrieval info: PRIVATE: DataBusSeparated NUMERIC "1" -- Retrieval info: PRIVATE: IMPLEMENT_IN_LES NUMERIC "0" -- Retrieval info: PRIVATE: INIT_FILE_LAYOUT STRING "PORT_A" -- Retrieval info: PRIVATE: INIT_TO_SIM_X NUMERIC "0" -- Retrieval info: PRIVATE: INTENDED_DEVICE_FAMILY STRING "FLEX10K" -- Retrieval info: PRIVATE: JTAG_ENABLED NUMERIC "0" -- Retrieval info: PRIVATE: JTAG_ID STRING "NONE" -- Retrieval info: PRIVATE: MAXIMUM_DEPTH NUMERIC "256" -- Retrieval info: PRIVATE: MIFfilename STRING "" -- Retrieval info: PRIVATE: NUMWORDS_A NUMERIC "256" -- Retrieval info: PRIVATE: OutputRegistered NUMERIC "0" -- Retrieval info: PRIVATE: RAM_BLOCK_TYPE NUMERIC "0" -- Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_PORT_A NUMERIC "3" -- Retrieval info: PRIVATE: RegAdd NUMERIC "1" -- Retrieval info: PRIVATE: RegAddr NUMERIC "1" -- Retrieval info: PRIVATE: RegData NUMERIC "1" -- Retrieval info: PRIVATE: RegOutput NUMERIC "0" -- Retrieval info: PRIVATE: SYNTH_WRAPPER_GEN_POSTFIX STRING "0" -- Retrieval info: PRIVATE: SingleClock NUMERIC "1" -- Retrieval info: PRIVATE: UseDQRAM NUMERIC "0" -- Retrieval info: PRIVATE: WRCONTROL_ACLR_A NUMERIC "0" -- Retrieval info: PRIVATE: WidthAddr NUMERIC "8" -- Retrieval info: PRIVATE: WidthData NUMERIC "8" -- Retrieval info: PRIVATE: rden NUMERIC "0" -- Retrieval info: CONSTANT: LPM_ADDRESS_CONTROL STRING "REGISTERED" -- Retrieval info: CONSTANT: LPM_INDATA STRING "REGISTERED" -- Retrieval info: CONSTANT: LPM_OUTDATA STRING "UNREGISTERED" -- Retrieval info: CONSTANT: LPM_TYPE STRING "LPM_RAM_DQ" -- Retrieval info: CONSTANT: LPM_WIDTH NUMERIC "8" -- Retrieval info: CONSTANT: LPM_WIDTHAD NUMERIC "8" -- Retrieval info: USED_PORT: address 0 0 8 0 INPUT NODEFVAL address[7..0] -- Retrieval info: USED_PORT: data 0 0 8 0 INPUT NODEFVAL data[7..0] -- Retrieval info: USED_PORT: inclock 0 0 0 0 INPUT NODEFVAL inclock -- Retrieval info: USED_PORT: q 0 0 8 0 OUTPUT NODEFVAL q[7..0] -- Retrieval info: USED_PORT: we 0 0 0 0 INPUT VCC we -- Retrieval info: CONNECT: @address 0 0 8 0 address 0 0 8 0 -- Retrieval info: CONNECT: @we 0 0 0 0 we 0 0 0 0 -- Retrieval info: CONNECT: q 0 0 8 0 @q 0 0 8 0 -- Retrieval info: CONNECT: @inclock 0 0 0 0 inclock 0 0 0 0 -- Retrieval info: CONNECT: @data 0 0 8 0 data 0 0 8 0 -- Retrieval info: LIBRARY: lpm lpm.lpm_components.all -- Retrieval info: GEN_FILE: TYPE_NORMAL Memory.tdf TRUE -- Retrieval info: GEN_FILE: TYPE_NORMAL Memory.inc TRUE -- Retrieval info: GEN_FILE: TYPE_NORMAL Memory.cmp FALSE -- Retrieval info: GEN_FILE: TYPE_NORMAL Memory.bsf TRUE -- Retrieval info: GEN_FILE: TYPE_NORMAL Memory_inst.tdf FALSE -- Retrieval info: LIB_FILE: lpm
