14 years ago --- Quote Start --- have run into an issue where one of the megafunction-generated VHDL files seems to have an error in it, and I was wondering if anyone on here could help figure out what is causing it. I dont really know much VHDL, so I was wondering if someone could explain to me why this isnt working. Also, I have not edited the VHDL file at all. Any help would be great! --- Quote End --- That is not VHDL. I suspect its probably AHDL (Altera's language). --- Quote Start --- Error: Text Design File syntax error: Text Design File contains MEMORY where a symbolic name or a number was expected --- Quote End --- Perhaps MEMORY is a reserved keyword, and the syntax checker is not smart enough to tell you that. Try changing the name to RAM0.tdf and see what happens. Cheers, Dave
