16 years agoMegacore IP with modelsim ?!?
I'm trying to simulate my desgin project containing the "tripple speed ethernet IP" i cannot simulate it in quartus because the arria 2 gx is not supported by the quartus simulator. In order to simulate it over modelsim i'll get these messages while compiling the "EDA netlist": Error: Can't generate netlist output files because the license for encrypted file "C:/altera/80/ip/triple_speed_ethernet/lib/altera_tse_crc32galois8.v" is not available Is there any way to simulate it before purchasing the license for it ? Thanks in advance edit: found this: Altera's free OpenCore Plus hardware evaluation feature allows you to perform the following actions with all Altera® IP cores and some partner IP cores:- simulate the core behavior within your system
- Verify the design functionality and quickly evaluate its size and speed
- Generate time-limited device programming files for designs that incorporate MegaCore functions or partner IP
- Program a device and verify the design in hardware
