10 years agoMaximum Operating Frequency
Hi everybody,
I designed a sample architecture in Quartus 10.1 by using EP4CE22F17C6. I used a bit generator and parallel mux blocks and run all architectures. I connect output of the bit generator to sel input of the mux blocks. When I added a mux block or removed a mux block, maximum operating freqeuncy of the system changed. I think that this case can not influence maximum operating frequency, because all mux blocks consists of same code and operate parallel. The System's clock name is clk and I write "create_clock -period 0.25 -name clk_100 [get_ports clk]" in SDC file. I atteched my files in this message. I could not solve this problem. Can anyone help me? Thank you very much.
