10 years agoMaximum Operating Frequency
Hi everybody, I designed a sample architecture in Quartus 10.1 by using EP4CE22F17C6. I used a bit generator and parallel mux blocks and run all architectures. I connect output of the bit gener...
10 years ago --- Quote Start --- but thats it - the path is not always fixed. When it does the fit, the logic can get put in different places, so the routing delays can vary from build to build - hence the variability. --- Quote End --- Tricky and Alex96 thank you for your comments. I now understand it. I obtained some examples in chip planer and atteched at this message.
