ashbinbabu
1 year agoMAX10 Same Code Fitting Differently Each Time
Hi, We are using MAX10 in our server motherboard. Let's say our code has 3 main sections - A, B and C. Whenever I am making a small change in Section C, the working of Code in Section A and B are ch...
RichardT_altera
1 year agoYou may checkout this user guide for further details on logic lock.
https://www.intel.com/content/www/us/en/docs/programmable/683230/18-1/regions.html
If seed = 6 yielded the best results, you can use it as the initial fitter placement. However, keep in mind that modifying the design or Quartus settings even slightly will usually change which seed is best for the design.
Richard Tan
