Making Nodes visible to SignalTap
- 1 year ago
I tried (* preserve_for_debug *) in VgaDisplay.sv but that still won't show vic_screen_lines in STP. I tried "Design Filter (all names)" as well - it still doesn't appear when I click List.
It is not listed in the 2 optimization result reports for removal, I can't find it in the compilation output, and I certainly can't see it in the RTL Viewer so it must have been removed somehow.
BUT.. I have just this minute tried searching for *vic_screen_lines* - and it appears! So I will have to remind myself to always use the asterisks either side of the node. I feel so stupid now - thank you for joining on me on this journey.
Always surround with asterisks, Sparky! Always!
Editing your design code has nothing to do with project assignments. You have to either use the Assignment Editor or edit the .qsf file directly. Is that what you mean?
Anyway, looking at that code, you should really try registering those signals. That will certainly guarantee that they will be tappable in Signal Tap. It looks like you're just doing a bunch of math and not generating any logic.
When you say "registering those signals", what do you actually mean, sorry?
Here's another case for example:
bit [7:0] vic_screen_lines; assign vic_screen_lines = vicScreenCharHeight << 3;
I have other assign statements that use vic_screen_lines but I cannot view them in SignalTap.
I tried this too but it made no difference:
(* noprune *) reg [7:0] vic_screen_lines;
- sstrell1 year ago
I mean supply a clock and create registers to store the values. Basic RTL design practice.- SparkyNZ1 year ago
Contributor
Oh, so if the registers aren't modified on a clock cycle (ie. within an always block or state machine), then maybe registers are not inferred? Is it possibly because I have "continuous" logic here rather than clocked (flip-flop) logic?
Please excuse my limited experience - I'm still a beginner/dabbler. Maybe it would be good for me to scale down a smaller project and see what is actually produced in the RTL Viewer.
