13 years ago
M144K and M9K memory blocks combined
I am working on Stratix III EP3SL150F1152CN FPGA. I am trying to port a hardware with 524,287 bytes (4,194,296 bits) of data RAM and 2048 bytes (16,384 bits) of address ROM. The total capacity of the FPGA is 5,630,976 bits with 16 M144K blocks and 355 M9K blocks.
Theoretically the devices should meet my memory requirements. The tool tries to fit ROM in M9K block and that goes without any problem, but when the tool tries to fit RAM, it uses M144K blocks only and as it exceeds the memory limit of all M144K (i.e 144K x 16), the fitter complains that design cannot be fit in FPGA.
I was wondering if it is possible to combine M9K and M144K together to use all of FPGAs memory blocks for my design? Any insights would be helpful.
Thanks in advance.
    Thanks a lot kaz!!
    However, there was a small bug in the code, and for future reference, here is the corrected one. Basically, the output was not synchronised a.k.a delay mismatch between input and output.
    library ieee;
    use ieee.std_logic_1164.all;
    library altera_mf;
    use altera_mf.all;
    entity tta_altera_onchip_ram_comp is
      generic (
        init_file_g  : string  := "init_data.mif";
        dev_family_g : string  := "Cyclone II";
        addrw_g      : integer := 10;
        dataw_g      : integer := 32
      port (
          address : in  std_logic_vector (addrw_g-1 downto 0);
          byteena : in  std_logic_vector (dataw_g/8-1 downto 0);
          clken   : in  std_logic;
          clock   : in  std_logic;
          data    : in  std_logic_vector (dataw_g-1 downto 0);
          wren    : in  std_logic;
          q       : out std_logic_vector (dataw_g-1 downto 0)
    end tta_altera_onchip_ram_comp;
    architecture SYN of tta_altera_onchip_ram_comp is
      signal sub_wireH, sub_wireL : std_logic_vector (dataw_g-1 downto 0);
      signal clk_enH, clk_enL, clk_enHD: std_logic;
      constant byte_size_c : integer := 8;
      constant bew_c       : integer := dataw_g/byte_size_c;
      constant widthad_a_in: integer := addrw_g-1;
      component altsyncram
        generic (
          byte_size              : natural;
          clock_enable_input_a   : string;
          clock_enable_output_a  : string;
          init_file              : string;
          intended_device_family : string;
          lpm_hint               : string;
          lpm_type               : string;
          numwords_a             : natural;
          operation_mode         : string;
          outdata_aclr_a         : string;
          outdata_reg_a          : string;
          power_up_uninitialized : string;
          widthad_a              : natural;
          width_a                : natural;
          ram_block_type		 : string;
          width_byteena_a        : natural
        port (
          clocken0  : in  std_logic;
          wren_a    : in  std_logic;
          clock0    : in  std_logic;
          byteena_a : in  std_logic_vector (bew_c-1 downto 0);
          address_a : in  std_logic_vector (addrw_g-2 downto 0);
          q_a       : out std_logic_vector (dataw_g-1 downto 0);
          data_a    : in  std_logic_vector (dataw_g-1 downto 0)
      end component;
    begin
      q <= sub_wireH(dataw_g-1 downto 0) WHEN clk_enHD = '1' ELSE
    	   sub_wireL(dataw_g-1 downto 0);
      clk_enH <= clken and address(addrw_g-1);
      clk_enL <= clken and not address(addrw_g-1);
      altsyncram_component_high : altsyncram
        generic map (
          byte_size              => byte_size_c,
          clock_enable_input_a   => "NORMAL",
          clock_enable_output_a  => "BYPASS",
          intended_device_family => dev_family_g,
          init_file 			 => "UNUSED",
          lpm_hint               => "ENABLE_RUNTIME_MOD=NO",
          lpm_type               => "altsyncram",
          numwords_a             => 2**widthad_a_in,
          operation_mode         => "SINGLE_PORT",
          outdata_aclr_a         => "NONE",
          outdata_reg_a          => "UNREGISTERED",
          power_up_uninitialized => "FALSE",
          ram_block_type		 => "M9K",
          widthad_a              => widthad_a_in,
          width_a                => dataw_g,
          width_byteena_a        => bew_c
        port map (
          clocken0  => clk_enH,
          wren_a    => wren,
          clock0    => clock,
          byteena_a => byteena,
          address_a => address(addrw_g-2 downto 0),
          data_a    => data,
          q_a       => sub_wireH
       altysyncram_component_low: altsyncram
    	generic map(
    		init_file => init_file_g,
    		intended_device_family =>dev_family_g,
          ram_block_type		 => "M144K",
          width_a                => dataw_g,
        port map (
          clocken0  => clk_enL,
          wren_a    => wren,
          clock0    => clock,
          data_a    => data,
          q_a       => sub_wireL
       delay:process(clock)
    	begin
    	if(clock'event and clock='1') then
    		clk_enHD <= clk_enH;
    	end if;
       end process;
    end SYN;
