17 years agoLVDS transmitter maximum output clock
Hello. I don't understand this (datasheet Stratix II GX, volume 2 10-17)
"The ANSI/TIA/EIA-644 standard specifies LVDS transmitters and receivers capable of operating at recommended maximum data signaling rates of 655 megabit per second (Mbps). However, devices can operate at slower speeds if needed, and there is a theoretical maximum of 1.923 gbps. Stratix II and Stratix II GX devices are capable of running at a maximum data rate of 1 gbps and still meet the ANSI/TIA/EIA-644 standard." I want to operate at maximum speed outclock whit divide factor 1. So my outclock frequency is the same of output_data_rate. Megawizard maximum output clock is 717mhz. Can I work at greater frequency? How?
