CSegu
7 years agoLVDS Interface and PCB layout requirments
Dear Sir, I am using ALTERA LVDS_TX and LVDS_RX IPs to implement LVDS communication in loopback on a custom developed FPGA board. I have developed the firmware and runs on the CYCLONE V GX starter k...
AnandRaj_S_Intel
7 years agoHi,
If design is working on Dev Kit, then board need to be checked.
since we are not seeing the rx_clk, we can suspect that pll from board design point of view.
- Check RREF_TL, If any PLL, REFCLK pin, or transceiver channel is used, you must connect each RREF pin on that side of the device through its own individual 2.0-kΩ +/- 1% resistor to GND.
- Also check VCCA_FPLL
- VCCH_GXBL and VCCA_FPLL must always be powered up for the PLL operation.
Try to create a simple pll design and see if we are getting expected output to eliminate the above doubt.
For LVDS PCB layout requirements refer below links
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/wp/wp_lvdsboard.pdf
Anand
