LPM_FF megafunction
I want to use the LPM_FF megafunction for my project. I want the LPM_WIDTH to be 8. I added that in the parameter field. Quatra II is not recognizing the change even after I saved the BDF file. The compile error is that the bus width with the input bus does not match. What is the correct method to add parameters to an LPM block. This is the first time I am using LPM. Is there an Altera file that describes how to change parameters in megafunctions? I am using the latest version of Quatra II.
Using Quartus Prime Lite 15.0, FPGA: MAX104 Replies
1. check here http://www.alteraforum.com/forum/showthread.php?t=36797
2. the latest version Quartus Prime 15.1. 3. to update IP Parameters -> open Project Navigator, IP Components tab, Right Click desired IP,Choose Edit in Parameter Editor. When you finished with editing allow tool to overwrite existing files for IP. - Altera_Forum
I am using Prime Lite edition. I don't see any IP components tab in the Project menu. Is the Project Navigator a different tool? don't see anything useful in the tools menu either. Can you expand on item 3?
btw, I am using Prime Lite v15.1, FPGA MAX10. thanks for your help - Altera_Forum
I found it. It is called IP catalog.Thanks for your help. I have not tried it as I am stuck at another problem. Will check out tonight.
IP Catalog -> it is where any old megafunction may still exist and Megawizards for IP Components. Shortcut key Alt+7
IP Components in Project Navigator -> list of instained IPs. Shortcut key Alt+0 for Project Navigator, then choose IP Component in combobox. check here http://www.altera.com/support/training/university/materials-tutorials.html by the way Parameters in schematic only as information they don't pass to compilation. You should rely on Parameters for IP provided through megawizard.
