10 years agoLPM_FF megafunction
I want to use the LPM_FF megafunction for my project. I want the LPM_WIDTH to be 8. I added that in the parameter field. Quatra II is not recognizing the change even after I saved the BDF file. The c...
10 years ago1. check here http://www.alteraforum.com/forum/showthread.php?t=36797
2. the latest version Quartus Prime 15.1. 3. to update IP Parameters -> open Project Navigator, IP Components tab, Right Click desired IP,Choose Edit in Parameter Editor. When you finished with editing allow tool to overwrite existing files for IP.
